Perform this procedure to configure the remote Intermediate System-to-Intermediate System (IS-IS) manual area.
  1. Enter IS-IS Router Remote Configuration mode:
    enable
    configure terminal
    router isis remote
  2. Configure the manual-area:
    manual-area xx.xxxx.xxxx...xxxx
Configuring remote IS-IS manual area:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis remote
Switch:1(config-isis-remote)#manual-area c1.1000.000.00
What to do next
To verify the configuration, see Display IS-IS Remote Area Configuration and Display IS-IS Area Configuration.
The following table defines parameters for the manual-area command.
Variable Value
<xx.xxxx.xxxx...xxxx>
Specifies the remote IS-IS manual-area in the range of 1 to 13 bytes.
